Top speeds: 48v VS 72v
3 posts / 0 new
Redheadjj
Given the extra batteries needed, extra weight, and increase wind resistance, how much increase in top speed can be gained using a 72v. Crystalyte 5303 versus 48v. ? If everything else is the same: my weight, bike frame, tires, etc. )
Re: Top speeds: 48v VS 72v
in a permanent magnet system (with no current limit) speed is linear to voltage.
so going from 48v to 72v increases speed by 50%.
Mick46
Last seen: 12 years 3 days ago
Yes. I will second the notion that it should increase
the speed by 50% but is usually not the case. It all depends on
constant amps/watts coming out as well. Of course you must measure under
controlled conditions.
