I need a controller for a common grocery store martcart
3 posts / 0 new
dieterschmied
I have a couple of Martcarts of the type that are used at Walmart. In fact, they came from Walmart. They are equipped with a 12 Volt DC, 60 Watts brushless hubmotor for locomotion. I am getting no output to the hubmotor and I can make the hubmotor turn if I wire it directly. The Martcart goes forward and backward and the brake is internal in the hubmotor (when power is cut to the hubmotor, it brakes)
The cart seems simple. Does anyone have any recommendation as to a cheap controller that will work.
Dieter Schmied
dieterschmied [at] gmail.com
robert93
robert93's picture
Re: I need a controller for a common grocery store martcart
have you thought about checking here....
http://www.martcart.com/
just a thought....
dieterschmied
Oh , they have them at $250.
I was thinking of something more economical. I would think that for such a simple cart there might be a generic controller.
