Deafscooter have a Customer who order the custom made scooter
13 posts / 0 new
Deafscooter
Deafscooter's picture
Deafscooter here....
I got a customer who ordered the Custom made E Scooter with Fastest 50 - 60 mph stand up scooter
Hi Craig, Deafscooter
what I'm looking
for (I need a fold down handlebar). I am thinking maybe it would be
better for me to order a custom scooter from you. Can I tell you what
my ideal scooter would be and you can tell me whether it is possible to
build to that spec, and if so, how much it would cost?
So ideally, I like something based on a BladeZ frame because I need to
be able to fold down the handlebars. I also need some modification to
lock down the handlebar in the back so I can pick it up by just the
handlebar like a luggage. I do this currently by wrapping a chain
around the bottom of the scooter and on top of the handlebar, but it
takes time to do the chain each time I have to carry it up stair.s
I'd like it to go 50 - 60 mph, with a range of 8 miles.
For batteries - I was thinking four of those new A123 batteries. I'd
need to have the BMS still installed because often I cannot unplug it
when it is done charging - I need to be able to plug it in and leave it
plugged in over night.
As for the components - I really like the work you did on the 2002
Currie Lightning where all the components are in the housing. I leave
the scooter locked outside sometimes in the city so I can't have the
parts exposed for people to try and steal.
I also like how with the backplate on the Currie you can have a second
person hanging on behind.
I'd also like the charger itself to be housed inside the main unit, so
I
can pull out a cable on one of those spring action cable winds and plug
it in. The charger definitely has to be part of the scooter though so
I
don't have to carry cords separately.
It'd also be nice to have some kind of trunk or basket to carry small
things or attach grocery bags. Also, I need to carry around a chain to
lock it up. I like to ride standing up, so no seat is necessary.
What do you think?
Thanks.
Deafscooter
Deafscooter have a Customer who order the Scooter
Deafscooter is Here..
you asked something to Craig Deafscooter what you want that feature
1)=> I'm looking for (I need a fold down handlebar).
2)=> I'd like it to go 50 - 60 mph, with a range of 8 miles.
3)=> For batteries - I was thinking four of those new A123 batteries.
4)=> I leave the scooter locked outside sometimes in the city.
5)=> I can pull out a cable on one of those spring action cable winds
6)=> have some kind of trunk or basket to carry small things or attach grocery bags.
7)=> So some kind of splash guard over the tires and the electronics protected ...
Deafscooter design the paper to for you look what i do for you a custom made
Scooter ( called Limo long Scooter allow two person Stand up and Basket on rear
also the battery packs in secured by allen bolt on it also charger will inside
the gage of frame also the Speed controller will local near sterring areas
and Tire will use 10 Inches ( bladez type tire and wheel ) the motor will
inside the Gage of Frame ( choice brushed or Brushless is option cost more )
the hand bar will design folding or height for your arm level .... also add on
Splash guard for riding rain Day .....
price minium is $4250.00 on metal Framework, Brushes type motor, speed controller ,
tire, wheel , Custom made Sprocket ,#35 chain, four AGM Batteries packs , safety key
Optional for add Cost on A123 Li ion Battery and charger station
Cost ius expesives
optional for add cost on Brushless ETek Motor with ABC Speed Controller system
When you ready want order the custom made the scooter for your need pay Money order on
Deposit for $3,000.oo US Dollar ==> before i start work on metalwork and allow 3-4 weeks to work time
Craig Uyeda
Deafscooter
Here is Picutre what i draw the draft on scooter before i work on it
if any correction then i can change the design the framework and style ...
Craig Uyeda === Image is Protected by Custom design scooter ©2007 Design by Deafscooter
deafscooter
Last seen: 1 year 1 month ago
Re: Deafscooter have a Customer who order the custom made scoote
What do you think?
Death trap
Deafscooter
Deafscooter is Here...
Emailed from My Customer what he Reply email to Deafscooter
hi Craig ( Deafscooter )
Sorry for the delay in replying to you - I've been pretty busy these
last few days. The price is higher than I was expecting. I was hoping
to be able to buy a scooter for less than $3000. How can we reduce the
costs?
I had some more questions for you ...
For the frame part, this looks like it also has the motor inside the
frame ... I don't know
though whether this is another cheap scooter or a nice one. The
website has it listed as a BladeZ. Would it save costs to try and modify this
one as opposed to building the frame from scratch? Or would it require
so many modifications that the custom frame would be better?
I was also thinking of perhaps going in a completely different
direction, and modifying a scooter like this ... that way I could use it
in the winter and be safer. Normally I just ride in the snow on normal
tires. I'm not sure though - what do you think?
As for the design you sent me though - I really, really like it. I'm
just debating with myself over the cost. Can you give me some more
information? Like what are AGM Batteries? How many charge cycles will
I be able to get out of the AGM battery system? I tried searching but
couldn't find anything about them.
Also,
What is the difference between brushed and brushless motor?
What is the sprocket?
What is the ABC Speed Controller?
For the existing design, the other specs I forgot to mention - there
should be a hole in the frame for me to loop through heavy duty bike
chain, and a way to store it on the scooter. I use this for mostly
city riding so I need to be able to lock it where ever I go in the city.
Also, there needs to be something built in to lock the handle bar down
to the other end of the scooter frame so that I can lift the handlebar
in the middle and pick up the whole scooter. Something that just swings
into place so it is fast and easy.
Sorry again for the delay. I'm really excited to get a good scooter, I
just want to make sure everything is right and that I understand all
the
trade-offs, since I am spending a lot on it and will be using it every
day. Like, what is it that makes the scooter go so much faster? Is it
having more batteries, or having a better motor, or controller? Or do
you need to have them all?
Are you on any instant messenger so we can talk more about it?
Message From Customer
Customer want correct the design like this one ... over the design......
My Customer asked three question is ==>
1. ) What is the difference between brushed and brushless motor?
you know motor is Brushed and Brushless
2. ) What is the sprocket?
Special custom Gear Ratio for Match Weight to Fast / Range
3. )What is the ABC Speed Controller?
BLDC Brushless DC Speed Controller with three wire output like 1,2,3 ( A,B,C )
4. ) Like what are AGM Batteries?
AGM is ( AGM (Absorbed Glass Matt) batteries have huge current flow discharge cycle
like orange hawker battery
The 100 pound small scooter it not possibles go Fast like 60 mph ( max is 40 mph top )
The 200~225 Pound large scooter with eTek Brush or Brushless could go 50-60 mph
The limo Scooter about 64 inches long allow carry two person and large motor
The 100 Pound as small scooter like 48 inches long ( most bladez scooter )
The Price have depend on custom made speed controller , motor , modding, metal etc,
custom speed sprocket , battery packs ( hawker battery or Li ion ) , some titanuim parts
Plus Labor on welding/laser cutter supply expenses ( Co2 gas, agron, wirefeed,Tungsten
Craig Requier is $3000.oo is minuim to deposit before craig start work on custom mods
This Picutre Small Scooter like this one ( Not ) go Fast 50-60 mph & carry 2 person...
Craig Uyeda
Deafscooter
deafscooter
Gman
Gman's picture
Last seen: 17 years 7 months ago
What's the price on something like that?
Peace Out,
Gman
What is your vision for the future our growing community?
Gman
ArcticFox
ArcticFox's picture
http://www.basestationzero.com/xtreme/x600index.php
www.BaseStationZero.com
davew
davew's picture
What do you think?
It's certainly original. Way more creative than pills. It does lack the earthy, organic quality of hemlock and arsenic, however. I don't think the results will be any less messy than using a handgun. Everyone has the right to be silly though so I say at the very least make sure your will is up to date before trying it.
Full time ebiker
BionX and Wilderness Energy
Sturdly
"Everyone has the right to be silly though so I say at the very least make sure your will is up to date before trying it."
I can only add, try not to take any innocent bystanders with you.
Gman
Gman's picture
` :jawdrop:
Deafscooter
I missed seeing the minimum deposit amount, what's a estimate on the final cost?
BTW, I notice you said you had several X Treme XM-2000's, inquiring minds what to know, what kind of Mods are you going to do to them and at what cost?
Peace Out,
Gman
Gman
ArcticFox
ArcticFox's picture
Several? I saw he only had one.
Gman
Gman's picture
` :D
My bad, I saw something he had 6 off.
andrew on Thu, 08/02/2007 - 19:30.
Quote:
( deafscooter have one too )
What? Only one? Thought he'd have 12 by now Eye-wink
Peace Out,
Gman
Gman
Deafscooter
:? :( :O
Im wait for customer pay as deposit $3000.oo before i start work on build off the scooter
Craig Uyeda
Deafscooter
deafscooter
theleland
that's going to be one *killer* scooter!!!
May I suggest an airbag jacket?
http://www.hit-air.com/english/main.html
http://www.motoair.com/
