Schwinn Missle FS
Fluid72
Schwinn Missle FS
Can someone inform me how to remove the rear swing arm?
e-doggies
e-doggies's picture
Re: Schwinn Missle FS
Remove the two machine screws from the ends of the pivot pin and remove the "stops". You should be able to drive the pin out the end. Use a large brass drift just slightly smaller than the diameter of the pin. Do not use a steel punch, or anything so small that it may mess-up the threads in the end of the pin, or expand the pin making it harder to remove. Hope this helps. Why are you removing the swing arm?
Fluid72
Thanks I will try that. I am re-painting the entire scooter and it would make it easier.
e-doggies
e-doggies's picture
And you'll get a nicer finish, too. Hope the pin comes out easily.
It would be great if you could post a pic after it's painted. Doing any other mods?
Fluid72
I will post pics. Can some one post the proper bolt sequence for re-assembleing the rear wheel with drum brakes? I forgot how it goes and nothing is working. From bearing out would be nice.
