BMS PCB
8 posts / 0 new
patm0007
BMS PCB
Where can I buy a new PCB for the BMS on my Lifepo4 battery. The battery is a 36V , 20Ah with 12 banks of batteries.
thanks
Pat
Re: BMS PCB
patm0007
Re: BMS PCB
Thanks for the info. The BMS is kind of expensive. Ping sold me one for $50 but he would had preferred selling me a battery with BMS!
But I like the batteries. Looks like it would be easy to build a 36 or 48V pack using the 10h lifepo4 cells
Thanks again
patm0007
Re: BMS PCB
Received the BMS. It is a signalab 12 cell BMS. I Need the wiring diagram to hook it up. I guess the C- is for the neg lead from the charger? the B- and the P- terminals ? one is for the batt neg? and the other batt pos, I'm not sure.
Any help would be appreciated as I don't want it to go up in smoke.
Pat.
Re: BMS PCB
http://www.all-battery.com/protectioncircuitmodulefor3cellslifepo12batterypack30A.aspx
Is that the same BMS?
wiring diagram on the same page.
patm0007
Re: BMS PCB
Yep, that's the same one. Appreciate the info as I was about to hook it up with batt + to the P- terminal!
Thanks again,
Pat
patm0007
Re: BMS PCB
Another Question: Can I just tape the BMS on the battery without a heat Sink?
Re: BMS PCB
those BMS shunt rather small amounts of current (50mA)
no heat sink is fine.
