I finished my Ebike project
8 posts / 0 new
daxter409
The bike has a 24v 8.8 amp motor, 2 12 volt 12 amp hour lead acid batteries wired in paralel, and a 250 watt universal controller with a twist grip throttle.
Here are some pictures. Enjoy!
The bike
The motor and sprocket
The gear welded to the wheel
The brace
The batteries
The controller
The motor
I tried to write a decent description of all the parts and process of making it in detail, but it is really long and I have bad writing skills. If you need any information in particular about what a part is and where it is from, or why something is where it is I can post it for you, just reply and ask.
daxter409
Re: I finished my Ebike project
I meant to say the batteries are wired in series, not paralel, my bad!
Last seen: 8 months 6 days ago
how is the left-side sprocket mounted to the wheel?
Trans-Port-Station
Trans-Port-Station's picture
This needs a fully enclosed chain guard !!! Also watch the wood piece touching the brake mechanism - It might slow you down a bit. Weight is to high for practical use. All Wires and electrical connections also need to be fully enclosed. FYI Electric bikes are required to have a brake to motor cut off.ie. when you pull the brake the motor cuts off.
"think outside the car"
Dauntless
Looks like there's six bolts through the sprocket and a flange inside of the spokes, although I can't see the whole thing. Seems the same as the moped engine kit I've been putting together. But a much nicer sprocket, I'll take it.
WHo dares, WINS!!!!
daxter409
The sprocket on the left side of the axle is welded in place, not bolted. The bike is working, but there are still things that need work, like the chain guard, motor cut off etc.
ElectricBikeBuilding
ElectricBikeBuilding's picture
Interesting. It looks like you had fun making this ebike. No chain guard looks dangerous but like you say, you're still working on refinements. I've though of trying a project like this. I don't think I'd ride it on the street because of the power and weight but it would be fun to build.
Ebikeparts
Ebikeparts's picture
It is very interesting. I think all the products on your bike is from us.
http://www.b-t-n.cn/BTN.jpg
Kevin
China ebike parts wholesale business cooperative.
http://www.b-t-n.cn/ www.b-t-n.org
Online shop: http://www.aliexpress.com/fm-store/904105
Phone: 86-0-15869111868
Skepe: kevin.fang168
Email: hz1stcare [at] 163.com
M s n
  • Jim Caudill
