Looking for a good hub motor
Monty P
Hello - long time lurker, first time poster here,
Wondering if you all have a recommendation for a Hub motor?
So far I have focused on Crystalyte 408
http://www.electricrider.com/crystalyte/x-408r.htm
and High Tek Bikes' rear motor -
http://www.hightekbikes.com/rear-motor-kit.html
I have a controller - I work at a company that makes them and I'm looking forward to showing off a electric bike controlled by our controller.
Question is, how hard is it to interface with the Crystalyte motor? The installation instruction look pretty specific to there controller.
Also, are there any other lower priced hub motors that I could buy on the web?
proton
proton's picture
Re: Looking for a good hub motor
FalconEV.com has motors
Prudence
Hello,
Good day. Give you a piece of suggestion. Your motor should be matched with your controller. If you just buy a separate motor, the parameters of the motor should match the parameters of the controller. If not, the electric bicycle can't be work. So it's better for you to bring the controller together with you to the motor shop. Otherwise, you may buy the useless motor yourself.
Good luck.
Prudence
Prudence
Chongqing Astronautic Bashan Motorcycle Manufacturing Co., Ltd Wuxi Branch
Tel:0086-510-88768223
Fax:0086-510-88768223
Mob:0086-13771553103
Http://www.chinabashan.com
Skype:bashanebikeprudence
Mail:wuxibashanebike [at] yahoo.cn
Hotmail: pruden
Monty P
That is good advice.
I ended up going with a nine continent motor through ebike.ca, an ebike.ca controller and a ping battery. The system works great, I already have 350 miles logged!
davew
davew's picture
Bionx. They are more expensive, but worth it. I have owned three hub motors in my time. The Bionx is the first one I bought (about 4 years ago) and the only one that is still working.
