36 Volt Izip has lost power
blairg
blairg's picture
My Izip running on 36 volts was running great until recently when it has lost significant power. It now has the performance of about a 24 volt. Anybody have any ideas why ?
Re: 36 Volt Izip has lost power
The batteries may be defective, allowing the voltage to drop below 33 volts under load of accelleration.---Connect a good voltmeter, and measure voltage WHILE OPERATING it, preferably on a slight UPHILL climb.--Bob
PS: A good 36 volt, lead-acid battery will measure over 41 volts at full charge completion. (12 volt lead-acid batteries will measure over 13.6 volts at full charge completion.--
blairg
blairg's picture
Thanks for the suggestion but I have two lipo batteries and one lead acid and the performance seems to be the same on all of them.
Any more ideas ?
blairg
blairg's picture
I took it apart and it had overheated and was burnt
jateureka2
What was 'it', the controller?
E-BIKES: [1]Ezee Sprint [2]Aprilia Enjoy Racing [3]eLation V2 e-bike kit on Trek 4100 [4]Bafang BBS01 kit on Fluid Momentum [5] FreeGo Hawk
E-SCOOTER: 2012 ZEV 7100 LR, 84V 60Ah nominal battery with 28 series GBS LFP cells
E-MOTORCYCLE: 2011 Zero S,
