Parting out my EVT 4000e
2 posts / 0 new
Jenn Rodriguez
I fried my motor and am parting out my beloved EVT 4000e because my job changed and, even with a new motor, I can no longer commute on it.
I have two chargers, two controllers, four B&B EB50-12 batteries (at least half-good by my estimate), tires (new and used), custom windshield, yellow trunk, rear rack, seat, yellow body parts, brake pads, etc.
Contact me if you need any used EVT parts!
Jenn
Santa Clara, CA
jennrod12 [at] gmail.com
adrian_nye
Last seen: 9 years 12 months ago
Re: Parting out my EVT 4000e
I would buy the shaft with magnets from your motor if they are intact. This could be
true if your wiring burnt out.
Have you taken the motor apart? Good instructions here:
http://www.7gen.com/book/my-ev-projects/cleaning-evt-hub-motor/701
The gear puller your can get for $12 at harbor freight. It helps
to duct tape it on while you use it.
Adrian Nye
Austin, TX
