POWER TAP!!
Submitted by Cell Propelled on Mon, 04/11/2011 - 15:25
You know,...thinking about this, what if I went behind the head light to grab the higher amp circuit to backfeed outside power of 12v power into the system feeding at a low volt, but helping the amps for distance,...and maybe have a refreshing affect on helping the front first out cell that everyone keeps talking about that fails. I would think that I would have to go back before the switching at the feed of the 12v, so it will be not after the headlamp command.
Stu
Topics:
- Cell Propelled's blog
- eric01
- Norberto
- sarim
- Edd
- OlaOst
Comments
Re: POWER TAP!!
the only twist to that is
when the light is turned off
nothing connected to it will work
some ware in my poking around the net
I came across a company selling a power converter
it would cut the volts down to 12 volts just like a car needed
so once a main connection to the power was dun
then you could connect a couple of items to it
what you could do is buy a 12 volt batter small enought to fit in the storage box
and get a separate charger for it
and run stuff off that
just some thing to think about
Re: POWER TAP!!
Hello Resourceful,
I do realize the power would be cut off, I was thinking where the source is before the switching, where it sits waiting with 12v,...tap there.
Stu
