POWER TAP!!
Cell Propelled's picture
You know,...thinking about this, what if I went behind the head light to grab the higher amp circuit to backfeed outside power of 12v power into the system feeding at a low volt, but helping the amps for distance,...and maybe have a refreshing affect on helping the front first out cell that everyone keeps talking about that fails. I would think that I would have to go back before the switching at the feed of the 12v, so it will be not after the headlamp command.
Stu
Comments
the only twist to that is
when the light is turned off
nothing connected to it will work
some ware in my poking around the net
I came across a company selling a power converter
it would cut the volts down to 12 volts just like a car needed
so once a main connection to the power was dun
then you could connect a couple of items to it
what you could do is buy a 12 volt batter small enought to fit in the storage box
and get a separate charger for it
and run stuff off that
just some thing to think about
Hello Resourceful,
I do realize the power would be cut off, I was thinking where the source is before the switching, where it sits waiting with 12v,...tap there.
Stu
