anyone know where i could find a 48V 5ah (110v) lifepo4 charger with an XLR connector ?
ray42dove
its for a 48v 12ah Lifepo4.... thanks! i have been having the most frustrating time locating one anywhere on the net..... :(
ray42dove
Re: anyone know where i could find a 48V 5ah (110v) lifepo4 ...
im sorry that charger was supposed to be 5amp not 5ah.....
colin9876
There are some around, e.g.
www.diytrade.com/china/4/products/8471893/48V_5A_Automatic_and_intelligent_battery_charger.html
It may be cheaper to buy 2 48v 2amp chargers off ebay for $15 each, then wire them in parallel!
Cut the connector off one and join its output wires into the other outputs
ray42dove
hey thanks! i looked at your link then searched a little more and found this similar one.... i guess i dont see an XLR connection.. could i just bypass the xlr port on the scooter and go straight to the battery with the connecter off of this charger on ebay? thanks again for your help!
colin9876
Yes you can go straight to the battery, or buy the correct adapater for $2 and solder it on to the charger - its easy to do
JLGRAU
I think that I have a few of those xlr connectors laying around. I removed them from chargers and replaced them with computer type plug ins.
If you want an xlr, send me a PM. Also, you can get a 48v 5 ah lifepo4 charger on ebay from lifepo4 battery vendors, but they usually come with a computer style plug in. You'll have to determine polarity and solder accordingly.
You can buy a 48v SLA charger with xlr plug in, but it will only give you about 54 volts tops. not enough to trip the bms.
