i recently got a schwinn s750 elec scooter for my kid.i think its a 05 and the problem im having is when i plug the charger in to charge it the green light stays on sayin its charged but when turnin on the scooter n trying it it goes right to low batt light.so my question is is the charger bad or the batt shot?
- sarim
- Edd
- OlaOst
- Iber
- AndresV10
batt is shot.
I have a Zip e750 and I have had the same problem. Yet, when I was talking with the factory tech, I realized the wiring is not superior debugging the problem as the tech thought it was the controller. I found problems with the harness and the charger. I can't post the entire problem/solution, but if you are still interested, give me a call as I'm willing to help. It might save you like it has me from buying a battery or controller. 8593824304
I have a Zip e750 and I have had the same problem. Yet, when I was talking with the factory tech, I realized the wiring is not superior debugging the problem as the tech thought it was the controller. I found problems with the harness and the charger. I can't post the entire problem/solution, but if you are still interested let me know as I'm willing to help. It might save you like it has me from buying a battery or controller.
