Baja Motorsports BE 500
Just purchased a Baja Motorsports BE 500. I have noticed a lot of complaints about charging the batteries. I discovered, after trying unsuccessfully to recharge mine, that there is a Canadian version of the owners' manual onlne. It is almost identicle to the US version but it says,"make sure the MASTER SWITCH is turned ON when charging". This is the reverse of what it says in my manual. I tried it and the batteries immediately started to charge. Just thought I'd pass that on. I don't know how that important detail was overlooked. I hope it helps you out.
Comments
robert93's picture
the common problem with these things is the charger overcharging, and not shutting off, cooking the charger and batteries. If you want to keep that scooter, get a different charger, and a timer to run it on. Good luck
Thanks Robert,
I have noticed that the charger doesn't ever seem to shut off so I've been careful not to let it over heat.
LJ Lester
