E-Bikes Going Up Hill a
11 posts / 0 new
Don S Schaeffer
Don S Schaeffer's picture
Has there been a major improvement in the hill-climbing ability of e-bikes over the last 2 years? I dream of getting a throttled e-bike but I live in a hilly area and I wonder if it would be useless.
longislandelect...
Re: E-Bikes Going Up Hill a
I believe there has been a good amount of improvement in the hill climbing ability of some ebikes in the past couple of years. In part this is due to the power, but it also has to do with the weight of the bikes and the type of motors they use. I believe the bike you have has a 250watt motor, which is one of the smallest motors out on the market today so I can see why you might have some issue climbing hills. It's also a standard brushless motor, which isn't the best for hill climbing, especially with low wattage. A geared motor like in the Easy Motion Cross or similar would give you much better torque, particularly under load. Another option would be to choose a higher wattage direct drive motor like the Currie eFlow or the Currie Zuma depending on what you are looking for. I'd be happy to help you find a model that is fitting for you if you'd like. Feel free to call me or email me if there is someway I can be of service. -Chris 631-306-4542 chris [at] longislandelectricbikes.com
We sell and service quality electric bicycles from top brands like Currie, Easy Motion, Stealth, Pedego and more. Check out our website for more info at Long Island Electric Bikes
Don S Schaeffer
Are you the only dealer on Long Island who sells E-bikes? I am very impressed with your letter. Unfortunately I am a retired man with no cash. I would consider a new throttle type bike if I could find one cheap, but not this year. Thanks for your response.
Trek Ride Plus Power assisted bike
longislandelect...
At this time I think I'm the only electric bike dealer on Long Island. Please let me know when your interested in upgrading and I'll do my best to take care of you. You're also welcome to come by and try a few out anytime. Feel free to drop me a line and we can setup an appointment for a demo.
- Chris
631-306-4542
vdp
vdp's picture
Throttle uphill is poor, but paddle-assist makes all the difference (leveling the slope). See my recent experiences, at http://vdpluijm.blogspot.com/2013/06/a-hybrid-bike.html
aowa ebikes are junk
aowa ebikes are junk's picture
eight points, oui
My old 450 watt EZIP Trailz is a great hill climber - the geared motor setup works well for that. It does slow a lot on the very worst hills, and I have to assist in first gear, which I rarely use otherwise, but a gearing change would solve that, assuming I could actually find a 8 tooth motor sprocket. The stock gearing works quite well for my mix of mild hills, moderate hills, steep hills and flat runs.
heres your 8 tooth sprocket. pop it off the shaft. file it to fit. used it on above bike and its predicessor. craftsman garage door opener drive gear.. drive sprocket.jpg
eight points, oui
My WAVECREST mountain bike has no problem taking me uphill, and I weigh 200 pounds!(Bike is 36 volt, 750 watt, direct rear wheel drive, USA made, but no longer sold here, see "MATA" of France, for present day version.
CiteCycles
CiteCycles's picture
I think you are right that in the hill-climbing are Electrical bikes can't give the good result because of low watt motor .If we increase or use the Hp Watt motor then it will give best result.
citecycles.com
Camile1702
Hello Guys!
How is a good Electric bicycle Front Fork. I am ready to buy a new Electric bicycle, so I want to know more
