How many Vectrix reached 100.000 km?
52 posts / 0 new
The classic post revisited,
dedicated to Antiscab and Grillino75... ;-)
Re: How many Vectrix reached 100.000 km?
christmas next year probably for me :D
May the IGBT power be with you!
ofx210p
I wish there was a 'like' button - that is a great phrase !
electricatalan
Hi! Roger!another catalonian ev fanatic!.I'm thinking on the purchase of VX-1 nimh on Barcelona.Maybe I can get one for about 1000 eur or less.I heard on www.forococheselectricos.com that you and Santiago had converted a VX-1 nimh with lithium batteries.I live in Barcelona too.It's difficult.Would you buy a nimh vectrix from 2007-2008?.
I,m "just only" 44.444,5 Kw away...
That's a long way, I guess it will take me around 6 years to reach that mark.
happy riding!
kingcharles
kingcharles's picture
I am almost at 50.000 (on still the original battery!!!) but the next owner will probably see that number in the display because yesterday I placed an order for the Brammo Empulse!
The EU type approval is almost done so they are shipping bikes to Amsterdam now. Maybe in April I ride my new bike.
-why are all my posts double now, after the website rocketeering? -
... because yesterday I placed an order for the Brammo Empulse!
And learn to shift through 6 gears, use a clutch and brake the rear wheel with the left foot again :-)
robwhite
robwhite's picture
image_3.jpg.
Hope to get to 100 k in a couple years ...touch wood
Running 40 ah li pack
rob white
Last seen: 2 days 22 hours ago
I think you mean right foot?
O course LOL! That just shows how far removed I have become from motorbike shifting :-)
And except to make it a "real motorcycle" (and allow easy wheelies) what is the purpose of 6 speeds and a clutch in an electric motor powered vehicle?
-double-
The clutch is a necessity for a normal "manual" gearbox to work, as gears cannot be changed under load. And about 3 different gear ratios would make sense for an electric bike like the Empulse, to enable it to make more use of the electric motor's power over the full speed range possible with that power. With electric motors there is ALWAYS a tradeoff between maximum torque / efficiency and maximum speed. With just one fixed gear ratio there is limit to the power which is actually usable. Above that you need a second gear to be able to reach the maximum speed possible with that amount of power, and if you have as much power as the Empulse even a third gear may make sense. With just one fixed ratio tuned for maximum speed the pickup from a standstill would be ridiculously slow with that bike. You can also use a smaller (cheaper...) motor with gears and still get some fun out of it...
The six gears are complete and utter overkill, unless Brammo really used a miniscule motor. But the six-speed electric motorcylce gearbox was readily available from the Italian company IET, so that is how the Empulse wound up with about 3 gear ratios too many.
"Only" 40K away... How'dy your odometers?
Rob944
So it is possible.
A Vectrix VX-1 can be reliable.
Got mine back yesterday after a big and long repair.
It has only 9000 km on the odometer.
robwhite
robwhite's picture
image_9.jpg (12.45 KB)Mine has now covered over 80k now but a battery died last nightimage_9.jpgimage_8.jpg
rob white
Impressive mark!
I guess the time of the leaf cells has come to your vectrix...
I passed the 100'000km mark today :D
I wonder what happens at 200'000km....
Jonathanm
Hi Matt - I guess that means that you have to change your signature...:-)
arno
Nice, i have a long way to go.
Only 20.000km on it.
2009 Vectrix VX-1
Wooowww Congratulations!
100.000 km on a Vectrix! This is an odissey! I,d love to read a small text about your vectrix... how many mc have been blown, how many batteries had to be replaced... funny situations... epic rides...
I guess at 200k you vectrix will explode into thousand pieces and propel you to orbit the earth, no doubt!
Oh! and Anybody in this forum is in contact with Grillino75?
one spiel coming up:
okay, so I had the bike completely original up until 13'450km (June 2010)
at which point I sold the nimh battery to mik, and the ESD charger to hibba
I installed 44 x Thundersky 60Ah cells and a 165v 8A TC Charger (most cells were manufactured
in 2010, but 4 were manufactured in 2008)
Some timer later I removed two cells to improve low speed performance and to test a few
things. at this point I swapped to a 153v 15A TC Charger
some time later that TC Charger failed, and I bought my present charger, a 153v 10A unit (I
have had this one for 3 years now)
I burnt out two MC's, and I am now on my third.
My present MC has reinforced phase terminals of my own design - replaced around a year ago.
MC''s seem to last me around 40'000km, though I am hoping better from this one
a few years ago I rode way too far and thought I had killed a couple of cells.
I swapped my two spares in, and bench tested the two I thought I had killed.
They revived and came back with a capacity of 52Ah
They have sat on my shelf ever since
Both the two I thought I killed and the two spares were 2008 manufactured cells
I only ever discharge to 46-48Ah at a maximum, as measured by my cycle analyst
One day when I do some time i will do a proper capacity test
so still on essentially the same battery since June 2010/13'450km
I am on my 9th rear tyre and on my 6th front tyre
brake pads are worn to 40% remaining (still original)
orma54
hi guys..
I reached 82.000 km in 4 years with my first VX1 li+ 42Ah GP batteries (almost at their end...)
now I added a second one to my garage with a 70Ah amita battery pack and I already rode 5.000 km in 2 months
Marco from Italy
robwhite
robwhite's picture
image.jpegI finally made it to 100000 KLm's after purchasing the scooter back in 2008 with 1800 KLms on the speedo. Now running Nissan Leaf batteries and doing a daily round trip to work and back of 65 kLms Every thing running reliably now ... Who knows how much longer it will go? ( still on original mc board as well) Sorry about the upside down pic I have problems posting via iPad
rob white
Tue, 07/05/2016 - 15:49
I'm "only" at 75K km... congratulations to all those who reached 100K km!!!
Edit Thu, 10/06/2016 - 09:59
just hit 80K! 5k in 3 months.. this is the "LEAF" effect....
Edit Mo 11/07/2016:
50k miles = 80.5k km!
Sugarstorm
100.000 kms! DONE!!!
And still going strong.
I'll meet you all at the 200.000 mark!
Just passed 90'000 miles or 145'000km
Wow antiscab, what a distance traveled?! Congrats! No troubles with gearbox, encoder, chargers, tempsensors, blown capacitors, ...? Ah yes, MC troubles?
