Vectrix lithium distance problem
Hi my names Kevin and i have a vectrix 13 plate Lithium and im having problems with regards the quoted distance of 50 60 miles, im only getting at best 20 to 22 mlis, could any body point me in the right direction as to what i should be checking ? have I got some bad cells if so how hard is it to remove all to find the Batteries and again can you change bad ones out easilly.
thanks for any help.
kevin
Comments
You may want to post this as a question in the Vectrix forum rather than a blog entry..
