1) Am I using the correct version for a VX-3? I would guess it would be what ever is best for a VX-1 Li.
2) I got green connection and status lights and some live data (such as MC volts) but X.XXX for all the cell voltages on the BMS page. Why would this be? Might I have the wrong BMS.hex file loaded?
Here is the files I am using. Is there any way to save the existing file '003316-03-BMS24withbootloader.hex' or get a copy of it in case it is a better choice then anything else I try? I am concerned since there do not seem to be that many VX-3s out there and this was a test bike that there might be some reason for this file. What BMS.hex file should I try?
Thank you in advance for any help and suggestions,
Cliff
I got my copy of the software here: http://vectrixparts.com/service-materials
It's a year newer than your copy, I think it's version 1.0.2.1, I have to reboot the computer from OS X to Win7 to see, so we'll go with this number.
You can also get the Lithium firmware there if your bike is out of date. Mine is NiMH, so I have not tried the HEX files.
-Randy
______________________
