I was frustrated that I could not get a copy firmware to update my new bike from this site, so:
I am going to try to upload text versions of the hex files. The problem is, I haven't tested this. Don't use these until I post that I have succeeded.
-Randy
begin 644 bcr3001.hex
M.C`R,#`P,#`T,#`P,&9A"CHP.#(P,#`P,#`P,3(P-#`P,#`P,#`P,#!C,@HZ
M,#(P,#`P,#0P,#`P9F$*.C$P,C0P,#`P8V8Y9#(P,#`X,&9F,C`P,#`P,#$X
M.#`P,#`P,#`P,#`Q.`HZ,3`R-#$P,#`P-3`P,#
______________________
begin 644 icmr1008.hex
M.C`R,#`P,#`T,#`P,$9!"CHP,C`X,#`P,#-!,D4X10HZ,#@P.#`X,#`X0C$S
M1D8P,#`S,$4X,S`Q0C8*.C$P,#@Q,#`P1D4P,#!!,#A&1#`P.$$P,3A#,3`V
M-#`P0T(P,44V,$(X,PHZ,3`P.#(P,#`Q,C)#,#@Q,#`U,S`Y-S`P,$,Q,3A#
M,3@S-C)#,$,Q1#5!"CHQ,#`X,S`P,#$U,D,Q-3`X03
begin 644 mc1017-68mph.hex
M`@HW.2`X,"`P,"`T-"`W.2`X,"`Q,R!&0R`W.2`X,"`P12`Q12`W.2`X,"`Q
M,R!&0R`W.2`X,"`Q,R!&0R`W.2`X,"`Q,R!&0R`*-SD@.#`@,3,@1D,@-SD@
M.#`@,3,@1D,@-SD@.#`@,3,@1D,@-SD@.#`@,3,@1D,@-SD@.#`@,3,@1D,@
M-SD@.#`@,3,@1D,@"C
Crap!
Oh well, it was worth a try.
-Randy
I hope you had better success installing the files on your bike than you appear to have done posting them to the forum.
Needless to say, I won't be tempted to install any of these files on my bikes as I think they all be the same 0mph firmware (AKA doorstop firmware).
Alan
Yes, thanks, the bike is running and charging great. Just need a new ESD charger to replace the one I stole from my other bike. These are 3 of the files that you sent me, the ones I used to update my bike. Not sure what you mean doorstop firmware. But they were UUencoded and pasted into a message, that was truncated when it was displayed. Even though I could go back in and edit the message and every line of text was still there.
Sad, I thought I was being so smart. I guess there is a limit to the message size or something, but even when I tried to truncate the message it failed. Must be something in the output of the encoded hex files that triggered it to display differently than just text...
-Randy
OK, I have uploaded those files to my dropbox:
https://www.dropbox.com/sh/hiqc24d5wkonr4t/AACOuC2JZ1uOcQ3fnqXdftwba?dl=0
Let me know if this works for others so they can transfer the .hex files to their computer.
-Randy
I have just downloaded them all as a single Zip file, unzipped and compared to the original HEX files I have and the HEX files were identical "byte for byte" when I did a file comparison check, so they should be 100% OK for others to use with ESD charger equipped bikes.
Alan
Yay!
-Randy
Check the new the laird's version of files, you'll get 70 MPH!
