Heated grips DIY
13 posts / 0 new
drgrin
drgrin's picture
Heated grips DIY
Last fall I've fitted heated grips to my VX. If anyone interested I can put DIY here.
martinwinlow
Re: Heated grips DIY
First off, can we have a picture or two, source, cost and some specs? But I think it would be worth doing a write-up anyway, myself. MW
Regards, Martin Winlow
Isle of Colonsay, Scotland
evalbum.com/2092
zeuz
I'm also interested in reading a DYI...
Last seen: 1 year 3 weeks ago
Also interested....
zeuz
I'm interested in fitting the Tecno Globe Gold heated grips, because they have the switch integrated to the grip, which I consider a plus:
Tecno Globe Gold Heated Grips
Could they be connected "directly" to an active power source ?
Or should they be connected to an auxiliary 12v battery ?
Could this auxiliary battery be charged with the traction battery, like in a Nissan Leaf ? (hence avoiding connecting an extra charger)
jasmim
I'm very interested. Please post DIY. Thanks!
Vectrix Vx1 Li+ 60Ah
jasmim
Please, post DIY, winter is coming...
jasmim
Finally I installed heated grips on my Vectrix Li+
Oxford heated gripes for scooters.
//i.imgur.com/NNli6NEl.jpg?1)
Cut up the old handles with a screwdriver to take off the handlebar.
//i.imgur.com/m2udBUvl.jpg)
I decided to put the switch on the handlebar cover in a discrete position.
//i.imgur.com/gulMRuKl.jpg)
//i.imgur.com/gLHj2byl.jpg)
Placing the LED power indicator . Green = low temperature. Red = high temperature.
//i.imgur.com/s2VF1iCl.jpg)
Pass the wiring for the steering column
//i.imgur.com/jQKXb38l.jpg)
And binds to the wires that connect the low lights
//i.imgur.com/pqJbp7Pl.jpg)
Storage all cabling
//i.imgur.com/7IxHrSkl.jpg)
Minimum Temperature = green light
//i.imgur.com/iVhMgNxl.jpg)
Maximum Temperature = rede light
//i.imgur.com/yTZazT7l.jpg)
BLUESTREAK
REALLY nice job.thanks.
Nice J!
If nobody posts it, DIY! Wonderful work, congratulations.
You have powered them with low beam wire system, haven't you? How many wh do they consume? Were they expensive?
jasmim
Nice J!
Thanks. Yes it's powered whith low beam wire. With high beam wire system my Vectrix have a light into glove box :)
I don't know how many wh they consume. Sorry. I Paid 48 eur.
Sacko
Last seen: 5 years 11 months ago
A slight bump :/
A quick glance on the specs and they pull roughly 4amps, can the low beam wiring handle that current?
It may be able to handle these extra 50W, however it's better to use an independent DC-DC,
