My conversion to lithium 18650 VX1
14 posts / 0 new
Vicens
Last seen: 4 years 2 weeks ago
Some details.
Make a conversion mikel to lithium.
Leaf cells are difficult to obtain.
I have a battery of a small scooter that want to recycle.
use a total of 784 cells 18650.
Samsung inr18650-29E cells with less than 50 cycles.
Sanyo ncr18650GA cells new.
9.54 kwh total capacity. at 25 ° C. at 100% charging, to 0% discharging, constant 1C discharge. Not take advantage of the full capacity. for longer life. The capacity will be less.
Make two or more packages. 36 cells in series.
Use bms of vectrixparts.
Cells without fuse assembly.
other details later.
Vicens
Re: My conversion to lithium 18650 VX1
Joining the first cells with glue. Make the first parallels of 22 cells.
Last seen: 12 months 4 days ago
Interesting idea for joining such cells :-) However, if that is hot-melt glue, it may melt during heavy use also as battery cells do warm up at high discharge or charge currents. But then again, if cells get THAT hot it would be highly worrysome and rather shorten their longevity...
Vicens
The cells can be heated a few degrees. high current charging or discharging.
However. BMS or controller cut the current, if you have a temperature sensor and is properly configured.
Hot melt glue is used in many batteries bicycles. No problem.
Vicens
Make the battery only with NCR18650GA cells. In a 38S22P configuration.
That's how it is in a box of batteries lifep4:
It should be 10S22P configuration at each height.
Fit 4 heights. for 40S22P settings. plenty more space above. space that could fit the bms.
Needless half the space of the battery. It would be possible to mount another charger in free space.
Vortex
Nice Job..
What is the maximum value to the cells? 4.10V?
Vicens
Nice Job..
The maximum values of the cells sanyo NCR18650GA are:
4.2v charging , 2.5v discharging.
Vicens
Nice Job..
Vortex
Nice Job..
Yes, but i asked for the maximum secure value that you put in the bms, 4.14V?
Vicens
Nice Job..
Bms ask for the value of charging balanced and discharging. No fit possible. The bms come in charging voltage 4.15V.
If you charge to 3.9V and 3.2V discharge. Get longer life. the capacity is 50%. This is useful if you have to make small trips. Different chemical operating at different voltages.
Vicens
Finish attaching the cells in hotmelt, blokes 11p.
Complete the first weld.
I have received different batch cells with different voltage, 3.65V and each other to 3.5V.
I made a test capacity of 4 cells, and all are in a similar capacity. of 3300-3400 mah. 4.21V charge and 2.85V discharge.
//i.imgur.com/aZF8A9c.jpg)
//i.imgur.com/utpUB1j.jpg)
Last seen: 1 week 1 day ago
Can't wait to watch these entire bunch of 18650 inside your vectrix!
You'll use vectrix BMS, won't you?
Vicens
I continue with the creation of the battery.
I had a problem with nikel strips. So far I have not been able to segir.
I am uniting the cells with hot glue.
//i.imgur.com/uV2v9Pk.jpg)
Vicens
I use a vectrixpart bms.
I think the best option.
The bms communicates with the charger and motor controller. if there is any problem. The battery disconnects the charger or the motor controller.
