Looking for a CAN-Bus USB Cable
2 posts / 0 new
SimonH
SimonH's picture
Hi Everyone,
I'm looking for a CAN-Bus USB Cable for my Vectrix VX-1.
Do I really need to get the one from Vectrixparts http://shop.vectrixparts.com/pcan-usb-ipeh-21e.html or can I use others.
Does anyone have one to sell?
Thanks for your feedback.
Simon
Heavendenied
Re: Looking for a CAN-Bus USB Cable
Yes, you really need this expensive cable. The Vectrix Diag Soft does not work with all the cheap cables...
The cable vectrixparts sells is from peak system and you can buy it directly from them, its cheaper there:
http://www.peak-system.com/PCAN-USB.199.0.html
or you can buy it from gridconnect, its also the same cable:
https://gridconnect.com/pcan/can-adapters/can-usb.html
I never heard of any other source for a cable working with the vectrix diag soft, besides used ones.
You do NOT need the version with optical isolation.
P.S.:
Just see you are from switzerland. Maybe you can find someone from switzerland who can borrow you a can cable... Maybe you should also aks in german vectrix forum:
https://www.twizy-forum.de/vectrix
If you want to buy i think for switzerland the cheapest is the one from Peak.
