CANbus adapter
Kevin_PA
CANbus adapter
I found and bought a used CANBUS adapter on eBay ($129)
The seller has some more of them.
https://www.ebay.com/itm/292701892076?ViewItem=&item=292701892076
It appears to be a PCAN-USB (IPEH-002021), but the unit has no markings or labels.
I loaded the drivers from the Peak website on my Win7 laptop.
When I plug in the adapter, the software recognizes it and the red LED lights.
In the control panel, the PEAK software recognizes the adapter and shows a firmware version of 4.2
And ScooterDiag seems to connect to it, since the LED starts blinking when ScooterDiag starts up.
So far I have not connected it to my bike, but I need to get a Female-Female adapter cable.
Bikemad
Bikemad's picture
Re: CANbus adapter
The cable required is just a simple Female to Female straight cable and does not need to be terminated.
Do not use a Null Modem cable, as it must be straight through connections:
Something like this female to female 9 pin serial straight lead should work fine.
Alan
Kevin_PA
Re: CANbus adapter
Thank You Alan, I built a cable as per the diagram and connected it up and presto - CAN Bus active!
I checked the electrical continuity from the USB connector to the CAN bus connections and determined it is the non-isolated type adapter, as I suspected.
2007 VX-1
Li-ion style
Re: CANbus adapter
Hi Kevin_PA,
Hi I'm the beginner for VX-1. Thank you for sharing the ebay link, finally got my hand on CANBUS now.
But can I ask you where you get the computer software?
Just can't find it or I miss looking somewhere.
If you can give me a little help, I'll be very grateful.
Shawnm
Re: CANbus adapter
Hi:
I saw your post about CANBus adapters. Are you saying that you just need a cable and no adapter?
Shawn
