Help with boosting a little-ion charger
3 posts / 0 new
carlos1984
Last seen: 3 years 12 months ago
Hi all I just bought a used hoverboard on an auction site but the charger supplied is wrong. It is 5v. The board needs a 36v charger rated at 42v 2a. I went through my chargers and found one that has a label with different voltages and 29 v at 2 amps checked off. So I opened it thinking there was a pot in it that I could turn to get the desired voltage. But it does not. The electronics board on the charger has ktj7225b on it. Is there anything I can do to uptrend voltage to 42v . Someone on a Russian site said to change the tl431 zener diode . I have uploaded the pictures of the charger.20210223_201502.jpg20210223_201438.jpg20210223_201334.jpg
Re: Help with boosting a little-ion charger
Three, ordinary low-amp 12V lead-acid chargers connected in series might work? I presume the hoverboard has an internal BMS?
KeithBook
Hi....As I would like to think on the off chance that you feel like your vehicle might require a leap or voyaging an extremely significant distance or basically need to be extra pre-arranged simply purchase a convenient leap starter they Can be had for just 45$ and can be a lifeline and afterward yo wont need to stress over fricasseeing your gadgets or in any event, moving your vehicle besides goodness and your companions can get it as well.
