XB-500 BURNED HUB WIRE-SHORT
KMCKALE
THE WIRE LEADING TO THE HUB MOTOR WORE THRU AND SHORTED.AS A RESULT THE UNIT ONLY GOES 3-5 SECONDS @ FULL POWER AND SHUTS OFF-IT WILL START RIGHT BACK BUT ONLY FOR 3-5 SECONDS-I HAD ORDERED AND HAD REPLACED THE CONTROLLER SO NOW IT RUNS WITHOUT SHUTTING ITSELF DOWN BUT IT ONLY GOES ABOUT AS FAST AS U CAN WALK.EVERYTHING ELSE WORKS-LIGHTS HORN.BUT I DONT KNOW WHY IT HAS NO POWER-IS THERE SOME THROTTLE CONTROLLER OR OTHER PART I MAY NEED TO LOOK AT.EXTREME SCOOTERS SEEMS TO THINK I MAY HAVE SHORTED OUT THE HUB MOTOR.IM A NOVICE AT THIS AND WAS JUST TRYING TO SEE IF I MIGHT GET SOME HELP OR SUGGESTIONS AS WHAT TO LOOK AT OR CONSIDER
ANY AND ALL HELP IS GREATLY APPRECIATED
sixpax2k9
Re: XB-500 BURNED HUB WIRE-SHORT
If you have not already I would check each individual battery in the pack. Make sure they are charging properly and to max voltage. If all the batteries are fine, then more than likely you have burnt out something in the hub motor. It could be a little of the windings or a hall sensor. I cant think of anything other than checking the battery pack and all the fuses and wiring in the bike than a "novice" can do. Testing the motor and or throttle may be beyond your scope and I can not think of an easy way to tell you how to do it at the moment. Perhaps someone else here can explain an easy way to do this. I do know the act of having power for 3-5 seconds, then cutting off, then coming back on, can be due to a severely under voltage pack. Normally caused by a bad battery in the pack or a bad charger not charging properly.
I will post if I can think of anything else....
Dave ; Tennessee
XB-600.
Did you remove the motor, take it apart and replace the damaged wiring with wire the same size or bigger? Are all wiring connections properly and securely soldered/connected? Sloppy or damaged wiring may be the culprit, and CAN cause other damage!-Bob.
mf70
You say:
Where was the insulation failure? What wire shorted? (color)
hguido1
You also should make sure you connected the hub motors wires correctly to the new controller. Is it a stock controller or aftermarket? I use an aftermarket controller and the color of the wires are the same but they don't hook to the hub motor the same as the stock controller. Not all controllers are the same even if the wires are the same color. You might check the hall sensor wires too if it is an aftermarket controller.
