My XM-5000li Experience
227 posts / 0 new
garygid
Re: My XM-5000li Experience
WOW, I had a great ride on my 5000li today.
I got my first real ride, going 35 to 50 mph over rolling hills to visit a friend about 18 miles away in San Juan Capistrano overlooking the ocean.
We had a great steak and potato lunch while the charger took about 2 hours to turn green. So, the 5000's battery might have been only 1/3 empty, but I did not (yet) have the confidence to do the return trip inland without a charge.
The temperature there was only 60º F so "scoot" did not overheat on the outbound trip. I was concerned that the return trip (about 77º F here) might overheat the motor, so I took a flatter, slightly slower route home, and I made it without overheating.
COOL ... (grin)
In short, a really nice trip, and I really enjoyed the "scooting"!
Next step is to get some motor temperature instrumentation. The interior structure of the "stator" is about the hottest part, so measuring the axle temp. might be sufficient. Maybe drilling a narrow hole in the right end of the axle, and inserting a thermocouple?
More later.
Cheers, Gary
Iccarus
Iccarus's picture
That is cool! I can imagine the views! Gary... it just keeps getting better too. I know what you mean about feeling a little insecure about range. I did an 80mi round trip to watch the shuttle launch from the beach in Florida. With more riding time, that feeling will go away. That's a good idea for the temp gage location. Using my IR gage I can definately confirm higher temps towards the center.
Cheers, Bill
garygid
Does anybody know how difficult it would be to drill a 1/8 inch diameter hole about 2.5 or 3 inches deep into the 5000li's rear axle?
Starting from the right end, drilling along the center line of the axle, I would like to drill in far enough to get "inside" the motor casing by about one inch. That would allow inserting a thermocouple sufficiently far in to get a reasonable approximation of the motor's internal temperature.
But, is the 5000li's axle likely to be hardened, or is it likely to be "easy" to drill. What "cutting fluid" should one use, and at what drill speed?
Cheers, Gary
Henry42
Green Light Trigger
I was researching the "Green Light Trigger" to see if that would help overcome the "getting stuck at traffic lights". Some say it's great, others say it is a waste of money. One person suggested using a magnet from a speaker. Does anyone have any experiences with these devices?
BTW. I came across this and thought I would share. How Many Bikers on a Forum Does it Take to Change a Light Bulb?
Iccarus
Iccarus's picture
Re: Green Light Trigger
I'm using 2 neodynium magnets (I hope I spelled that right) I got from RCdudes.com for 99cents each. It seems to be working but I'm not sure yet. Just stick them to the bottom of your battery box.
garygid
Google:
Detection bicycle demand-actuated traffic signals
where they seem to indicate that magnets and other small metal objects are essentially useless (even counter-productive?).
They say that since the "measuring" (exciting) frequencies used in the sensor loops are high (over 10k to 200k Hz), that a larger conductive loop like a bicycle wheel (or a "big" conductive plate like a typical car has) apparently gets eddy currents induced that tend to LOWER the effective inductance of the coils in the road (instead of acting like an iron-core that would RAISE the inductance).
So, adding a "large" conductive loop just inside a plastic-bottomed scooter might help more.
Also, ask the "local agency" to adjust the sensors for bicycles.
Cheers, Gary
Iccarus
Iccarus's picture
Ouch! that gave me a headache:) Well I got a left turn signal the other day I didn't expect but I'll try to do some real mythbusting soon.
garygid
Icc...,
You are riding the 3500, right?
Henry has both the 3500 and a 5000li. Presumably one should not get very different responses from the two bikes (in triggering Traffic Signals).
The article's hint to position the front tire right over (and parallel to) one of the sensor lines (if you can see them) might be worth trying.
Cheers, Gary
I've heard differing reports and tend to think magnets don't worth. Also bear in mind that you already have a lot of magnets already on your bike (in the rear hub - it's a permanent magnet hub-motor after all!)
Gary - I should be able to get you an answer on this in the next couple of days. If I don't post back here please send me a reminder. (Also, any word yet on sharing the XM-5000 data files?)
Iccarus
Iccarus's picture
You guys are probably right the magnet thing is probably BS. I'm sure I'll see soon enough if I get stuck sitting at a red light.
garygid
Sharing My PakTrakr Log Viewer
John H (and others),
I wrote a program (PTViewer) to give me a better view of the
data that is logged from the PakTrakr system, up to 48 Cells.
The program has really been quite helpful to AndyH and me, and
we can easily share data with each other. So, I have decided to
share my latest version (v3.7) with those of you who care to
download it and try it. I use it on WinXP Home (SP2 and SP3).
If there is enough interest in supporting another common data-log
format, I will consider adding the ability to read/write another
data format to the program.
For your convenience, I put my PTViewer program on-line,
along with a sample data log of charging my XM-5000Li with
the standard ThunderSky charger (supplied with the 5000Li).
You can visit www.wwwsite.com/scoot/ to download the zip file.
It contains the Visual Basic 6.0 exe file, the "sample" data
log file, and a short (yes, too short) readme.txt file.
John, when PTViewer works for you, let me know. I am still working on
getting an over-60 mph graph of the Pack voltage and current for you.
To all of those who have helped me, THANKS, Gary
Cheers, Gary
Re: Sharing My PakTrakr Log Viewer
It works for me :-)
buckda
Hi Gary,
Does you volt gauge actually work? Mine is pegged at full even after I've ridden 2 or 3 mile with the light flashing and the bike is only giving me a max speed of 10 MPH. I'm being told this is normal. Please confirm.
Darryl
buckda
Hi Gary,
Wow - how did you do it? I've hit a block wall both trips to the DVM. They say I need an emmissions report???
Is there anyway you can talk me through the CA registration process? Did you buy your from a web site in California?
I look forward to hearing from you. If its easier for us to talk my nubmer is 510-390-0122.
Darryl
csk111oc
Don't waste time with californias DMV!!!!! Just have a certified vehicle verifier come to your home, for $40-$65 they do all paperwork and deal with DMV. You just sit back and wait for your plates & registration. NO QUESTIONS ASKED. AAA has there own in office, so i've been told.
  • Iber
  • AndresV10
