Crimping Connectors
lampajoo
Crimping Connectors
I just got new batterys for my emax and I'm redoing the arrangement as is recommended, so I needed to put new wiring in. I went out and got some #6 wire and some ring terminals to match. However, I went to 4 places it seems that no hardware stores sell crimpers that will work on this size. Also people have been telling me I should just use pliers, but this seems like it would not make a good connection. What is a good technique for making high power connections? Is there anything that doesn't involve a super expensive crimper? I can think of various ways to do this but it seems like i should do it the right way>>>whatever that is?
I saw some solid copper connectors where you stick the wire in a hole then tighten a screw to hold it in. Would these be good enough for the job?
Re: Crimping Connectors
Check out this link: http://www.electroauto.com/catalog/tools.shtml
It's actually capable of #2 wire so might be over sized for what you need. Cost is $27. I've never used one - I just remembered seeing it.
John H.
Blue XM-2000
Ann Arbor, MI
lampajoo
thanks for the tip! I think I'll be getting one if no one has a better idea.
andrew
andrew's picture
Thats exactly what you need. Also one here: http://www.evsource.com/tls_cabling_tools.php#hammercrimper
Anyone got one they want to sell?
My KZ750 Project: here
Last seen: 1 year 1 month ago
I have a similar one which I bought from evparts.com
I bought a sledgehammer, and making cables is a great opportunity to whale away at something.
