need inexpensive charger
9 posts / 0 new
Webmaster
Webmaster's picture
Last seen: 4 months 4 days ago
Hi folks. I'm looking for a cheap 12v charger to use to charge a 12v 12ah scooter battery. I have a couple of these left over from replacing them in a 24v scooter. They're still good and I want to use them for powering my small 12v trolling motor. I don't have that scooter anymore...hence I don't have the charger...and the only other charger (besides the one for my 48v scooter) I have is a 6 amp automobile type charger but I'm afraid this might overheat them since I see most scooter chargers have about 1-2 amp output. Where can I get a cheap charger? Is my best bet just to buy a 12v scooter charger online and if so does that mean I can just cut the connector off the end and put a couple of clips on the wires and connect directly to the battery for charging?
Any help or recommendations greatly appreciated. I just don't want to pay much just to have a way to charge these small batteries safely.
Gushar
Gman
Gman's picture
Re: need inexpensive charger
I use a 12VDC 1500mA AC Adapter I got from Radio Shack and added 2 Alligator clips.
Tech specs
General Features
Model 273-1775
Product Type 12 Volt or less
Recommended Use Powers devices requiring 12VDC and up to 1500mA
Body Material Plastic
Miscellaneous Features
Supported Languages English
Power Features
Voltage Required 110/120 Volts AC
Power Type AC to DC adapter
single voltage Yes
Power Voltage 12VDC 1500mA AC Adapter
Peace Out,
Gman
Gman
gushar
Thanks Gman for a reply. I think I found something that might work. It's at the following link...from Harbor Freight (HF is right down the street from me)
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42292
If you have a chance could I impose on you to look at this and tell me if this would be suitable? I'd be most appreciative. The price is certainly right!
Gushar
Gus
Gman
Gman's picture
gushar my first response is that's perfect, I might get 4 like that at that price. Then I read the specs. The float may be too high, I assume your talking about charging old SLA from a old Scooter. Maybe you should wait for someone that knows a little more than I do.
I believe this is more suitable for a Car Battery or a regular Trolling Motor Battery.
I'll fwd this to a EV Tech.
Chicago Electric Power Tools Automatic Battery Float Charger
Specifications
Battery Float Charger: 12 volts DC, 5 to 125 amp hours
Voltage Output: 13.5 VDC
Dimensions: 1-3/4 x 1-1/2 x 2-1/4 inches
Total length from power module to connector clips: 53 inches
Input Voltage: 120 volts AC, 60 Hz, 14 watts
BTW, What do you fish for?
Peace Out,
Gman
Gman
jbird
You want a charger like the one below that has a bulk charge. A float charger will be slower and less effective but is an option if you can wait a very long time to charge.
http://www.zbattery.com/12bc1000d-1.html
You will need to order the leads for $1.50 or make your own like I did.
Gman
Gman's picture
jbird,
I like your suggestion better, It has LED indicates when charging and when charged
12V 1000mA Sealed Lead Acid Battery Charger
Input: 120V 60Hz 25W
Output: DC 12V 1000mA
Select wire adapter here (sold seperately - $1.50):
Alligator Clips
Female Cigarette Adapter
1/4" Female Spade Adapters
12BC1000D-1$13.45
Think I'll get 1 with a 1/4" Female Spade Adapters, if it works ok I'll get 3 more latter.
Peace Out,
Gman
Gman
gushar
Gman-
Yeah...that other charger looks like it would do the trick. Course I may just buy the one I posted the link to...and just see how it works. I'm sure it will take some time if it charges...but I don't need it fast. Just so it charges in a day or two. Anyway, it's even cheaper at the store...like $6.50. Guess it'll be a $6.50 experiment.
I fish saltwater and freshwater...but more saltwater (brackish where a river comes into a bay) more often. I fish for speckled (sea) trout, redfish (drum), white trout, flounder, etc....saltwater. I fish for bass and bream freshwater.
Sometime, when I have time I'll have to post a pic of my "electric kayak" which turns alot of heads down at the docks!
Gushar
Gus
andrew
andrew's picture
See what the output is before you buy it if you can.
500 mA * 24 hrs = 12 ah (rough calculation) = 1 day charge
250 mA * 48 hrs = 12 ah = 2 day charge
Anyone got one they want to sell?
My KZ750 Project: here
gushar
I believe it's 600 mA...so that will work fine according to those rough estimates. I don't mind it taking a day or so. Thanks for the info!
Gushar
Gus
