simple wiring help brake lights, running lights, turn signal
4 posts / 0 new
echuckj5
echuckj5's picture
I have most of the wiring figured out for my rear lights. Now, how do I wire the brake lights, when I apply my brakes will my turn signal not flash. For me the easy way would be to just run a third light for my brake light. It looks to me that automotive flasher, has 2 prongs, should be run like this, does it over ride the brake signal and keep just one of the lights flashing, will both lights flash if I hit the brakes?
Anyone know the proper wiring diagram to do this?
chuck
andrew
andrew's picture
Last seen: 15 years 4 days ago
Re: simple wiring help brake lights, running lights, turn signal
Your signal wiring is correct. Just have the brake switch, switch positive to both signal lights in a separate positive circuit. That way the flasher will not be in the circuit for the brake light switch.
I don't know if this is a good idea though because you might want to signal when you are slowing down with the brake a lot.
Anyone got one they want to sell?
My KZ750 Project: here
Stleride
Stleride's picture
andrew,
BTW as a EV Tech Advisor you now have the ability to do a Fileshare. Any problems let us know.
Stleride
Moderator Team Captain
Moderators are dedicated volunteer V Team members who help keep your V Forums running smoothly and provide Forum Support.
Stleride
Alpha Charly
Dear Chuck.
I have made many electrical diagrams to put in my vehicle (Land Rover serie I, 1956), it has the genuine red lamps, it were made only with brake and tail lamps; now is necesary turn signal.
There is a special swich that to finish with your problem ...... I have the plane of these one, but I was tinking a lot. If you want, send an e-mail and I´ll send you my plane, but to build the swith isn´t easy.
If you want, enter in www.evparts.com, and show the item SW9510 (turn & brake signal lever, 7 wires) ..... very beautiful, I have these one.
Bye
ADRIAN
