Schwinn MissileFS unknown electrical problem
33 posts / 0 new
Psychepsilo
Hi folks.
I'm new here and to electric motors (but I'm very mechanical).
My Missile FS was parked and plugged in inside my garage, which unfortunately has no door currently. A horizontal rain blew in and moistened at least part of it and tripped the breaker on the GFI outlet it was plugged into. (Or it could have been the surge from the lightning that also struck very nearby, but I think that would be a lot more obvious.)
I'm not sure what all got wet, as it didn't get wet enough to still be that way when I got to it the next day. I do know the charger was still wet.
Later that day I tried it out and it seemed as though the first time I turned the switch it worked for about 1/10 of a second. Now nothing works at all... the light on it doesn't come on, nothing happens, no noises or anything...
I've tried hunting around online for a manual of some kind for it, to no avail.
I'm very good in the garage, but I have no experience whatsoever with electric motors, so I don't know where to start. Any help at all would be appreciated!
e-doggies
e-doggies's picture
Re: Schwinn MissileFS unknown electrical problem
I'd start by checking the fuse. It's on the red wire coming from the battery pack under the deck. Pop the cover off the fuse holder and carefully remove the blade fuse. If you are certain it is good, return it to the holder and we'll go to step 2.
coldem
Sure sounds like a fuse to me. If it is not a fuse I would check the controller to see if the water blew it up. Those would be the only things I could think of
Psychepsilo
Thanks guys.
I haven't even opened it up yet, it's scheduled for tomorrow. :) I'm just in the habit of asking online questions before I get started so that by the time (and if) I get frustrated maybe some answers will be around.
Thanks for the quick responses.
Psychepsilo
All-righty-then.
So I opened it up, and both fuses were blown.
Took it completely apart and did some mods to it...
-Painted it blue (it's for my girlfriend, to run her husky with, whose name is Blue).
-Drilled some holes in the frame to run the control wire and rear brake cable through to neaten it up, worked beautifully.
-Covered the exposed wire and brake cables with copper braiding. Looks killer.
-Removed all the "Schwinn" black and red grip tape, to be replaced with black (or maybe white... can I get whitewall tires for these things?).
-Chopped off about 5" of its useless tail, and the plastic cover over it, so I can mount a basket on the back of it tomorrow.
-Pulled off all decals. (Not a fan of advertising for others for free... or paying for the privilege.)
-Thinking about painting a recycle symbol on the black disk that covers the gears.
-Will have to acquire new grips, they and the rear shock spring are the only red left (and I think the red spring is fine).
Now I have a fresh, new problem.
I had it up on sawhorses. As soon as I got the wiring reconnected and the wheel back on, I couldn't wait to see it spin again.
I flipped the switch, got the green light (which I haven't learned the meaning of... it didn't always come on), and twisted the throttle.
...and got that familiar electric popping noise from somewhere in the rear. No sparks or flame, and I didn't let the smoke out.
Reflexively released the throttle, tried it again, and nothing.
The light was still on, and another check of the fuses revealed that they were both still good.
Here's what I know:
I THINK the popping came from the controller unit.
I know I can bypass it and connect the batteries directly to the motor to verify a controller problem. (Or either, or preferably?, connect a 9v to it, right? Wouldn't be much, but would spin the motor a LITTLE BIT, indicating that it's good, right? Anyway... not very likely to have a 9v laying around... it IS OK to hook the scooter's batteries, or just one of them perhaps, to the motor for a moment without doing any damage, correct?)
Here's something I did:
Mom picked up fuses for me while she was out. The fuses that were in it were a 30amp and a 40 amp (don't know which went to where, didn't seem relevant at the time... just marked which one went where). The fuses she bought were 40 amp.
Since I realize that fuses don't actually DO anything, as long as conditions are normal... they just protect when something out of the ordinary happens... I figured it would be fine to use 2 40amp fuses just to get it together and try it out, and get a 30 tomorrow.
I still think that. I don't THINK the problem was caused by an incorrect fuse, I still think it was a moisture problem. However, since learning how the thing is put together I don't think there's much chance that the controller itself was wet... but then, the rain WAS coming in sideways, right at the back of the thing. It also appears that (and makes sense) that the motor is manufactured tightly enough that it's pretty unlikely moisture got inside it.
So, I'm both incredibly long-winded and mildly stumped. And again, I'm asking before I check.
Any ideas? I'm pretty sure I now need a new controller, which is easy enough to match up.
Summary, eh:
Ideas or comments about what the problem might be?
What's the best place to order a new controller from?
Hey... here's something else: While I'm ordering a new controller anyway, any suggested changes or anything? I see lots of mods get done to these things, mostly for speed. What I'm thinking about is the opposite: the scoot's top speed of 18 mph is more than enough for it's intended use. Info online says the Missile FS should go about 3-6 miles.
Is there perhaps a controller change I could make that would make it go a little slower for a longer distance?
I'm sure the dog can REACH 18 mph, but 10 mph is probably more like it for distance, and it would be really cool if she could get enough mileage out of the scooter to actually GO someplace on it.
A top speed more like 15, and range of maybe 8 miles would still be fun, zippy, and more useful. 12 mph max would be acceptable if it would go 8 miles or more.
Thanks, guys!
e-doggies
e-doggies's picture
Seems as though you've been busy.
Drlling holes in the frame is generally not a good idea as it weakens it. Periodically, inspect for metal fatigue, cracking, etc, around the hole.
Yes, I have seen whitewall tires for this size scooter.
I've opened up a lot of Currie scooters and have never seen one with two fuses before. Could you trace the wires in both directions to see what they are connected to. Are they both in red wires?
I haven't tried running a 24V motor on a 9V drycell. It MIGHT move it a tad. You can directly jumper from the motor to one of the batteries under the deck. That will give you 12V and hopefully eliminate the motor as a problem.
We might want to check some voltages at the controller before we toss it out. Do you have a digital multimeter or voltmeter?
The green light that doesn't always come on, is it the one right above the switch on the front frame tube? That one should be on whenever the switch is on and power is going to the controller. If it's not ALWAYS coming on, you have an issue with wiring, connections, or the main switch itself. Again, a DMM will be very helpful in your diagnosis.
You certainly could upgrade the performance. If you wind-up buying a new controller, you could get a 36V and a dd another battery. You will have a higher top speed at full throttle, but also 50% more WattHours which will give you more range if you don't run it full throttle all the time. Or, stay with 24V and add another set of batteries in parallel, or replace both stock batteries with larger Ah's.
What motor do you have on the Missle?
You said the "popping noise" sounded like it came from the back and you think from the controller, but if you have a brushed motor and a separate controller, the controller should be under the deck in the nose of the battery tray. So, I'm confused about the number of fuses you have and what that "familiar" popping noise is.
Psychepsilo
It's good to see someone actually reads every word of my post. I know I tend to be long-winded (and make no apologies), so I suspect people do a lot of scanning when I write on forums.
-"It seems as though you've been busy."
Indeed I have. Two good, solid workdays on it. The copper braiding thing took the better part of the second day. It was a pain... it was the first time I've done it, so there was a curve, and it just plain wasn't easy.
-"Drilling holes in the frame is generally..."
Thanks for the concern and suggestion. I'll definitely take a look periodically, but I'm not at all worried. Structurally I know what I'm doing, it's electric motors I have no experience with. Drilling a small hole still leaves a lot of metal, plus I drilled them in places where other supports would make up for the very slight strength degradation.
-"I've opened up a lot of Currie scooters and have never seen one with two fuses before. Could you trace the wires in both directions to see what they are connected to. Are they both in red wires?"
I wouldn't have thought it strange till I just looked closer at it. Now, being a novice, I'm completely confused as to why it would be done the way it is.
The circuit is: Positive (red) wire from battery -> 2 fuses wired in parallel -> up into the front tube to the on/off switch -> motor connector.
-"I haven't tried running a 24V motor on a 9V drycell. It MIGHT move it a tad."
Completely moot. Just my long-winded (fingered?) way of saying I wasn't sure if connecting the scooter's battery (ies) directly to the motor was a bad idea. You answered that.
-"We might want to check some voltages at the controller before we toss it out. Do you have a digital multimeter or voltmeter?"
Well, not a digital one. But we can still do some checking.
-"The green light that doesn't always come on..."
Yeah, you've got the right one. Actually though, I'm not sure if it always came on or not... maybe I just didn't notice it in bright sunlight. I don't pay much attention to little things like "on" lights when something is obviously on... because I'm riding it. Until this recent problem, it worked consistently and smoothly.
-"You certainly could upgrade the performance."
Getting a little ahead of myself on that one. Which is fine, but I've gotta prioritize. I can upgrade later if necessary. (Is there a way to adjust the throttle? [I imagine there is.] Like so that twisting the switch all the way [easier to maintain a constant speed] would be less than actual WOT?)
-"What motor do you have on the Missile?"
It's a Currie XYD-6B. 24VDC, 28A rated current, 450w output.
-"You said the "popping noise" sounded like it came from..."
The controller on the FS is at the rear of the deck. It hasn't been moved or anything, there are tabs there that hold it in place. No biggie... semantics... location, location and location.
LOL... the "familiar" part meant simply that being a tinkerer, this isn't the first electrical component I've fried in my time. There's something strangely sweet about the smell of the smoke from burnt electronics... kinda like gunpowder. (Something even more sweet about NON-burnt electronic smell... I'm a sound engineer, and one of the first things I do to get in the groove at showtime is lean over real close and smell that electric aroma from inside my mixing console.)
You probably know what I'm talking about... not so much a pop, as a quick, unnerving crackle. I could make the sound for you if you were sitting here with me... ;)
The motor and controller are about 8 inches or so from each other, and being that I wasn't expecting any problem I wasn't looking their way when I twisted the throttle (I feel funny calling a rotary pot a "throttle").
I guess if I'd let the smoke out of the thing, it would have been more obvious which component it was.
So here ya go... your point by point answer to your very much appreciated response to my post.
I will now go out and briefly wire a battery to the motor while I await another response.
I wasted a whole day (sort of), so I didn't get a chance to get the basket mounted on it. I'll get that done tomorrow, and then the "after" photos will be taken. I'll be glad to share them here, to show off the work I so enjoyed.
Psychepsilo
Opened up the controller... saw nothing obviously burnt or broken (never do, really), but sticking the ol' nose in it reveals an obvious burnt smell.
Connected one battery directly to the motor, and it tried to drive, unmanned, through the sofa. (j/k)
e-doggies
e-doggies's picture
So, the smell and the sound both point to a bad controller. TNCscooters has a good selection (I counted 18) of 24V controllers. Most will have only a three-wire throttle connection, but they also have 5-pin and 6-pin Currie controllers. How many wires do you have going from the controller to the throttle?
I'm pretty sure your throttle is not a "rotary pot" as in "potentiometer". Most likely a Hall-Effect throttle. Take a small metal paper-clip and lightly drag it over the throttle housing. If you find a place where it wants to stick, it's found the magnet for the Hall sensor.
You could put a resistor (or a pot) in the signal wire from the throttle to the controller. Then you could regulate the amount of voltage going from the throttle to the controller, and therefore could "trim" your top speed.
Something awfully strange about your fuse situation. Can't believe that is factory original. The parallel paths share the amp load, so you probably could have had about a 60A draw before the 30A fuse blew, then the 40A fuse would be carrying the entire load and would also immediately blow.
You really should remove one fuse holder and just run a 30A or 40A single fuse.
Here's a couple links:
http://www.monsterscooterparts.com/12-5-x-2-25-white-wall-scooter-tire.html
http://tncscooters.com/partsdb.php?type=ES
Good Hunting!
Psychepsilo
Again, dude... you rock, and thanks.
-"How many wires do you have going from the controller to the throttle?"
Three. (It will be easy enough to match up the right one, not gonna upgrade till later on.)
-"I'm pretty sure your throttle is not a "rotary pot" as in "potentiometer"."
Yeah, potentiometer is what I meant. But my main point about that was that it's not technically a "throttle," and being a motorcycle mechanic (of sorts) it feels funny to call it one.
-"You could put a resistor (or a pot) in the signal wire from the throttle to the controller. Then you could regulate the amount of voltage going from the throttle to the controller, and therefore could "trim" your top speed."
I can't say I definitely wouldn't have thought of that eventually on my own, but that's brilliant! Kind of creating a manual cruise control of sorts. I might have to try the pot thing.
Oh, and "trim"... you a sound guy too, or do we just share terms? (I know that since sound work is essentially electrical work, we share a lot of terms.)
-"Something awfully strange about your fuse situation. Can't believe that is factory original. The parallel paths share the amp load, so you probably could have had about a 60A draw before the 30A fuse blew, then the 40A fuse would be carrying the entire load and would also immediately blow."
I thought it looked really weird, and kind of ineffective, but again I admit I'm sadly quite far from an electronics wizard.
Though, I pretty seriously doubt it was modded by who I bought it from. Folks around here are pretty simple. And a "mod" that did nothing but add a useless fuse would be kinda unimaginable, wouldn't it?
And it LOOKS like factory wiring. But then, so does mine. ;) (Heh... I don't play around. My mod work is usually way better than the Chinese factory did. I actually walk around the corners that they cut.)
They definitely both blew, but I've already said that.
You a guru, bro? You pretty confident you're correct about removing one of them?
As a pretty sharp and understanding novice I do kinda agree... 2 fuses in the same line would simply mean that 2 fuses fail instead of just one, costing 50 cents to replace instead of a quarter.
Say it again, and I'll do it. (Got not much else to do while I wait for a part in the mail... grrrr)
e-doggies
e-doggies's picture
I have 5 Schwinns, 1 GT, and a Lashout and none of them have more than one main power fuse. You could remove one entirely, or just put a fuse in one holder and leave the other empty.
Psychepsilo
Alrighty then. Consider it removed.
I'm headed to the garage now to mount the basket, but I just realized I don't have any paint to really "finish" it. (Painting my mount black to blend in with the basket... or maybe I'll just go with the blue since I have it.)
One way or another, pictures either today or later when I get black paint.
Thanks again.
Psychepsilo
Alrighty, then...
It's done. Well, the mods are and pictures are taken anyway, I still need to order the controller.
If this is an active enough forum for it to matter, how exactly do I go about putting up pics?
Or, since there's only one other person besides me who seems to be involved in this thread, would you like me to email you some pics?
e-doggies
e-doggies's picture
The first button on the top left (on the page where you type your response) is "insert/edit image". After you go there, you will need to "upload" the pics from your PC.
Go ahead an post them here for everyone to see.
What controller are you going to order?
e-doggies
e-doggies's picture
Just making sure I could do it...
My GT Shockwave after a rather unfortunate incident.
I'll pull this when you post your pics. Don't want to mess-up your thread.
Psychepsilo
Haha... what'd you do? Get in a collision with a paint contractor's van?
I guess I'll have to put pics up on a hosting site or something. I don't know if the ones I put up on facebook will work... I'll have to see.
Psychepsilo
Alright, got it.
Here's the before:
After:
A closer detail of the copper braiding around the cables and control wire (look closely and you can see where the rear brake cable and control wire go into holes in the frame):
And a view showing the rear, with my homemade mount for the basket and the chopped tail:
Psychepsilo
I somehow missed your other post, but I figured it out. (Sometimes if you just look around....)
I figured I'd just order a controller like the one I'm replacing. Not sure off the top of my head, but I'm perusing ebay.
e-doggies
e-doggies's picture
Yeah, that looks nice. A scooter Blue will be proud to trot next to. The whitewall tires would complement his paws... That braid work looks great!
My Shockwave came that way from Craigslist. Just latex wall paint that came off with soap and water. Apparently, a paint can tipped over in their garage.
Psychepsilo
Thank you very much!
Psychepsilo
OK.... yet another question.
I'm having a hard time finding a replacement for the controller. Found one website that claims it's the only US supplier, and it's not available till the 15th.
With a simple search for "Schwinn missile fs controller" I found one that's slightly different, but cheaper and available. The main difference is that there's a connection for the battery charger, which my controller doesn't have. Do you know of a way to bypass or remove that connection?
Meanwhile, I guess we'll just be patient and do the back order thing.
Hmmm... I swear I had found another site that had the thing about a week ago, now I can't find it again.
I think it's strange that a direct search for "Missile FS controller" brought me to a part that isn't.
Dang interwebs. I guess it's a good thing that most of us DIYers are smart enough to know better.
e-doggies
e-doggies's picture
You would just leave the "charger connector" unconnected. It's not needed for your application.
Where have you been looking for a controller?
TNC does not have anything you can use?
Psychepsilo
So hey, well, yeah...
So I found the actual direct replacement controller, twice, and it was back ordered, twice.
Ordered the other one that I mentioned before, with the "extra" connector for the charger, simply not planning on using it. Delivered the scooter to the girlfriend, installed the new controller, and nada.
The green light above the switch comes on, but I get nothing when I turn the throttle. I looked closer, and found that the green and red and black wires on the new controller are reversed from where they are on my throttle connector (where they're also red and yellow, not black, but I don't see that as being a problem).
So I figure I can simply reverse those two wires from the throttle and it will probably fix it, but I haven't done it yet (busy) so I don't know. Any reason that's a BAD idea? I'm going to try a few things, but the last thing I want to do is wind up messing up the controller in case I have to return it.
Also... I decided to plug it into the charger to make sure it was nice and strong by the time I get it running, and the light on the charger doesn't come on. So I'm wondering if perhaps I can/should jump (connect together) the wires on the charger connector? Once again my limited electrical knowledge is screwing me. I'm guessing that since this controller is expecting to be connected more directly to the charger, but my scooter isn't designed that way maybe the charging connection THROUGH the controller (which apparently because of the connections I have, the charge IS going through the controller, just not through a separate connection) currently has a high-impedance air gap due to the open connector. My logic is telling me that connecting its posts together will fix the problem... but my logic is also telling me that if it doesn't work I might ruin the controller and not be able to get my money back if it's simply wrong.
Any further help, yo?
I appreciate it... the excitement of getting the thing down here has now diffused into not being able to show it off.
Thanks.
e-doggies
e-doggies's picture
Could you post a good clear close-up of the controller and all the leads you have attached to it? If it has a "brake" connector (often yellow and black, but not necessarily), leave it disconnected for your first tests.
Measure the voltage on the throttle wires coming from the controller. Write down the voltages you get across each combination and whether or not moving the throttle grip has any affect on the voltage.
With a voltmeter, Measure:
Red to Black
Red to Green
Green to Black
Make sure you have power going to your controller from your batteries/fuse/switch.
Come back and we'll get this thing going.
Controllers are generally non-returnable after they have been connected. TNC is putting them in sealed bags with a visible message that if you open the seal, it's yours!
Could you also sketch a wiring diagram that shows how you have your batteries, fuse, switch, controller, and charger connected?
Psychepsilo
I already tried switching the 2 controller wires like I said, and it's running great.
My problem now is simply the charger issue.
I ordered this:
http://www.monsterscooterparts.com/scmogti24v40.html
But it's not QUITE what they sent. It has the same stuff, sticking out of the end instead of the side, with the addition of another wire that I don't know what it is... it's terminated, but has a connector... I'm assuming it's for a brake cutoff that isn't in use on this scooter.
There's one more connector with red and black wires and a connector, that I assume is for the charger in some way since that's what's not connected or terminated, and that's the only thing that doesn't seem to be working.
My idea is that I can connect its two wires together and that will "connect" the charger. This didn't come in a sealed package, just a ziplock, so I think I might could return it. Of course, that's not what's most important... getting it charging is.
I've got other things to do, so I'll have to deal with taking a picture later or tomorrow. I'm going to go plug it in now and see if the other issue had something to do with it (I doubt it). Perhaps you can think of something based on this information? Or at least if my idea of connecting those two wires together would FRY anything... if not, we'll deal with it tomorrow.
By the way, I've already taken Blue for a ride, and it works AWESOME. I'd thought that because of the smaller wheels if she tries to stop or take off (which she doesn't do... she's already used to running with a bike) it might be an issue, but I did some pretty erratic riding and it was fine. Again... awesome!
e-doggies
e-doggies's picture
You are charging with a stock 24V charger with a XLR type plug? And a charger port on the scooter near the switch? There should be two thin wires on the charger port. The negative should go to the battery negative (it splices into the main power negative lead on my Schwinns). The positive would go to the battery-side of the main switch (always on). Wired like that, you simply plug your charger into the port and you do not need to involve the controller at all.
I would advise AGAINST shorting across two leads coming out of the controller (the red/black that you think is charger). I'd suggest you turn-on the controller, and check what kind of voltage (if any) you have across those two wires.
Have you eliminated the charger itself as the cause? Has it worked since the storm?
btw, all the plugs should have been labeled and there should have been some documentation indicating what leads attach to what. If there was nothing in the zip lock bag except an unmarked controller, I'd go back to the supplier before I blew up a controller and had to start over. Doesn't even sound like you got the one you thought you ordered?
Psychepsilo
Yes, it's a stock controller (as far as I know... bought it used), XLR plug, port on the scooter near the switch. Yeah... your whole first paragraph there is it.
The controller doesn't "turn on," the only switch on it is a fast/slow charge selector. (Any real difference, while I'm at it? I'd think just going with the slow is better, and don't see any reason to rush it ever.)
I am pretty sure I had already plugged in the charger after the storm and charged the scooter, and it worked. Though as soon as I acquire a multi-meter tomorrow it will be easy to check to make sure. (About the only tool I own and didn't bring down here with me is my multi-meter.)
Last paragraph?
Yeah, um, I'm not real thrilled with monsterscooterparts.com. There was nothing else in the box, no labeling on the wires, nothing but the part, packing materials and a ziplock bag.
What seems strange is that the "extra" connector that was pictured in what I ordered is the one I would assume is what was listed as the charger connector (a), and there's yet another one (b) on what I received. The little 2-wire connector (a) has a sort of terminator connected to it, as you'll see in the pictures. That one has two white wires going to it. The OTHER one, (b) is something completely unknown to me, and it also pictured. It's a white connector with two terminals, with red and black wires connected to it.
By the way, all of the labeling on the controller is correct, 40w, 24v, and it's running. The only problem I'm now having is charging (frankly, for all I know the light on the charger could be out and it could be working, but I doubt that).
And again, yes, I'm quite sure I had already plugged in the charger to make sure it wasn't a problem and it worked. Though, it's been well over a month now so it's possible I could remember wrong. Heh... but I've got another witness too.
So, here's a couple of pics... let me know what I should check next. (Two things... would this be easier over the phone? And... you realize I owe you good beer, right?)
I know they're a little vague, but hopefully they help. Again, thinner one with the black connector I think is the charger plug, because it matches the connectors in what I ORDERED, and I don't think it's the problem since it has something connected to it.
But then... since the other one ISN'T connected to anything, and I'm not charging... I could be wrong and I'm left clueless.
Thanks again.
Psychepsilo
Oh yeah... NOT pictured are, hopefully obviously, the stuff that is correct, connected and working.
e-doggies
e-doggies's picture
Sorry, the pics didn't help me. Can you get some in lots of light?
I would first persue a remedy from MSP. "Clearly they have shipped you a product that is not up to their usual standards, so there must have been an error somewhere." They charge more but seem to have good service. Give that a try. Start with a smile and you're likely to have a new controller on it's way to you. If not, there'll be plenty of time to scream and holler on the phone and bash them here again.
Seriously, I don't understand charging systems that go through the controller. None of my Schwinns is wired like that. They are as I described above. I think that you can simply ignore any leads that are identified as "charger" on the controller. Problem is, you have no labels on any wires, so can you be certain as to what wire is for what function?
My "gut" keeps telling me that your charger problem is a wiring issue. You plug the charger into the scooter, and then plug the charger into the wall, and the charger acts like it's not connected? Have you ever tried turning the switch "ON" with the charger connected to see if it changes the light status? If it works with the switch ON, you have the positive wire for the charger port on the wrong side of the switch. Then again, it may not be anything like this!
Psychepsilo
Update:
I did a little thinking, and I have to agree. I don't know what the unused connector is, but if the batteries are connected directly to the battery via the charger port then said connector has nothing to do with it.
I just checked for voltage at the XLR connector on the charger, and I have nothing at all.
We're on our way to pick one up this afternoon.
Meanwhile I think I'll do a little research on how to build one cheaper...
e-doggies
e-doggies's picture
Did the new charger fix your problem?
