Physical location of Battery Sensors and coresponding Reading in software
HarryS
Does any one know what physical location these temperature sensors correspond to.
The fron battery has 2 sensors on each level of the 3 stacks of batteries for a total of 6; so does the back battery. So I assume the 12 readings corresponde to 6 on the front and 6 on the rear.
Anyone knows
Mod Temp 1 4D
Mod Temp 2 4D
Mod Temp 3 4D
Mod Temp 4 4D
Mod Temp 5 4D
Mod Temp 6 4D
Mod Temp 1 4E
Mod Temp 1 4E
Mod Temp 1 4E
Mod Temp 1 4E
Mod Temp 1 4E
Mod Temp 1 4E
HarryS
Re: Physical location of Battery Sensors and coresponding ...
sorry I miatyped: the sensors are
Mod Temp 1 4D
Mod Temp 2 4D
Mod Temp 3 4D
Mod Temp 4 4D
Mod Temp 5 4D
Mod Temp 6 4D
Mod Temp 1 4E
Mod Temp 2 4E
Mod Temp 3 4E
Mod Temp 4 4E
Mod Temp 5 4E
Mod Temp 6 4E
Magendanz
Magendanz's picture
I found a damaged cell in the front pack, top platform, right side that corresponded to a high temp reading on Mod Temp 2 4D. Seeing that there are only two sensors per platform, one on each side, I'd conclude that sensors are numbered from left to right, top platform to bottom platform, and front pack (4D) to rear pack (4E).
Of course, that's making a lot of assumptions based on only one data point.
X Vectrix
Last seen: 2 years 12 months ago
An accurate assumption tho!
mikemitbike
mikemitbike's picture
Hi, so this should be the correct positions?
Greetings Mike
