Vectrix Lithium conversion kit V2 - with some CALB 70AH shoe horned in
40 posts / 0 new
Hi Guys,
I'm finally getting ready to sell the much anticipated 70AH conversion kit
here's a picture of a nearly finnished product:
Re: Vectrix Lithium conversion kit V2 - with some CALB 70AH ...
Oops, I mean this is the kit nearly finnished installation on a Vectrix:
This is how the kit will look as shipped (with the old nimh battery container as a packing material):
This is a direct link to the picture album:
http://s283.photobucket.com/albums/kk316/antiscab/
okay, more information on the kit:
Included is:
fwx 200A fuse
42 x CM060 BMS modules + blue box
plastic cover and spacers
battery interconnects
noalox battery paste
pre-charge light bulb
Aluminium seat bracket
stick on foam tape (to be used where the plastic meets the aluminium frame)
What you will also need to buy:
cycle analyst
50mV 100A shunt
42 x CALB SE70Ah or WB60AH cells (not sure yet whether the CA70Ah cells will fit)
silicone sealant (water proof variety)
what you will need to extract from the parts removed from the Vectrix:
anderson connectors
the hook from the fan cover
the back plastic from the fan cover
What tools you will need:
torque limited drill
USB-CAN Cable
socket set
screw driver set
wire cutters
automotive crimper
soldering iron
and finally the price:
This version of the kit is US$2500 + shipping
As usual, payment is by paypal, US$1250 on ordering, and the remainder when ready to ship
I have one kit ready to go, and most of the bits ready for two more (lead time on those two is 3-4 weeks)
after that, lead time is 8 weeks
The video is still a work in progress, hopefully I can get it done this weekend
CO2
And modification charger to charge 70ah?
Looks a bit awkward to ride :)
^^^forget that...only first photo showed up initially!
Thats what you need the USB-CAN adapter for - to load a version of firmware The Laird wrote to allow the charger to fully charge a 70AH battery
Not sure why the first post only had the one photo, but oh well
I was just reading the specs on CALBs new CA series of cells:
Only the older CALB SE70Ah cells will fit and the CALB SE60Ah will not
but the new CA series, only the 60Ah cells fit but not the 70Ah
its all about the cell width, 115mm is what is needed.
just as I'm thinking about this,
THe fuel guage with The version of firmware that allos charging of the 70Ah cells does not yet work, however, the voltage is shown while riding
at least one of the people who have purchase this new kit is planning on relying on that and not installing a cycle analyst
While I don't recommend riding with no Ah count, keeping an eye on pack voltage only may work ok
The risk is the bike won't stop you from overdischarging the cells, but the voltage sagging below 120v while riding is where you would stop
Sounds easy to monitor.
kingcharles
kingcharles's picture
I am using The Lairds software for a while now and I never look at the fuel gauge anymore. I only look at the voltage readout now. At 130V I go into conservative mode and at 120V I consider it empty tank.
It made me think that the fuel gauge might as well be used as Voltage gauge also the same way it does when the charger fails.
CO2
So full discharge is ??? 102v?
that sorta works, except most of the capacity in a good pack will be between 125 and 130vdc
on the fuel guage when working as a volt guage, that represents 2 bars - not really enough to be meaningful
full discharge is between 115v and 125v - the reason I say between is you should stop when the first cell is depleted, but you can't tell from pack voltage alone as a single cell reversing only causes a voltage drop of 1.5v
best practice is to measure the capacity of the smallest cell and scale the fuel guage AH count to that amount
The problem is actually worse with the lithium kit, as the voltage stays the same for most of the discharge.
So the voltage readout will give you an idea when you should stop, but no prior warning that an AH based fuel would
That's why I recommend the cycle analyst
If you ever get an agent who can do this conversion in Melbourne, let me know. It might just be the arm twist I need to do it.
kingcharles
Looking at the pictures again I see only 20 CALB cells in the top layer. Are there 22 in the bottom layer?
Also, would another stacking method work for cells with more than 115mm width but less depth?
I was just looking at those 100Ah cells from the other thread and they might fit 5x3 laying and 3 high gives 45 cells.
Crazy idea or possible?
Yes, thats correct
That could work, as long as those cells don't mind being on their sides
The same approach could be used for WINA 100Ah cells
CALB would appear to no longer make the SE 70Ah cells, which is a shame.
I have found this cell that has the same dimensions though: http://www.ev-power.eu/WINA-30Ah-100Ah/WINA-LiFePO4-Power-3-2V-72Ah-aluminium-case.html
72Ah so even a slight increase in capacity.
CO2
Hi Matt,
so do you have try the 100ah cell?
And what do you think about Calb, seria CA 60ah (10C)
http://evtv-amsterdam.eu/proddetail.php?prod=CA60FI
I haven't tried the 100Ah cells yet - getting them into Australia is too expensive unless I find someone else already buying a large quantity from the same manufacturer.
I wouldn't mind trying the 100Ah cells for my next vectrix
My vectrix is has a worn head bearing. Once I get to 100'000km I plan to convert my spare vectrix.
The CALB 60Ah and 66Ah cells are a good shape
Here's a CALB CA 60Ah conversion (which I wasn't involved with):
http://visforvoltage.org/forum/13501-lithium-conversion-continued
Here's a CALB CA 66Ah conversion in progress:
http://visforvoltage.org/blog/manfredbartz/13540
CO2
I don't find any 66ah cell
http://en.calb.cn/Product/?id-116.html
Todd
Last seen: 3 years 2 weeks ago
I am thinking about using some of these. A local shop that converts ICE cars to EVs told me about them. They have been using them and had good luck, plus they have a 5 yr warranty and the prices seem good to me.
http://www.balqon.com/store/#!/~/category/id=2736691&offset=0&sort=priceAsc\\
I would like to use the 90 ahr but the only way I can think of fitting them in is to lay them on there side perpendicular to the tray and stack them. They should fit 5x front to back. The 60 ahr should fit in pretty easy though. The voltage is different from the CALB cells so I am wondering how many I would need?
they're the same voltage as the CALB
minimum cell count is 40, max is not really known but highest I have heard of is 45 cells (I personally have run 44 cells before)
fitting 40 of those 90Ah cells in is ambitious, maybe make a mockup before actually buying them
Todd
I was originally thinking 38 cells. I was taking into consideration they were to be charged to 4.0 V per cell and thinking the Vectrix charger won't go to 160 V with 40 cells. Also with a lower voltage limit of 2.8 V at 40 cells that would be 112 V. Will that work or is that to high for the Vectrix? Could the batteries be damaged before the red light came on? Excuse my lack of knowledge with the lithium, this is my first experience with them.
My measurements are that it appears I can fit 38 cells, 6 layers of 5 cells and then another 2 layers of 4. Again this is all rough math and the mockup is a good idea.
Those CALB cells are of the LiFePO4 type which should NEVER (apart maybe from the very first charge) be charged to 4V!!! End of charge should see them no higher than about 3.65V, and that will quickly drop to levels of around 3.4V, at rest. Better use those voltages for your cell count, otherwise you may be a little disappointed at the power of you converted VX1 ;-)
martinwinlow
Hi Matt,
A move at work is forcing my hand re battery sort out/upgrade.
I have an '08 Vectrix (just passed 15k miles) which has had a Runke charger installed.
What are the options as far as Lithium goes? Obviously I can't use the Laird's software but I have already an, as yet, uninstalled CycleAnalyst V3. Will I be relying on that for range remaining information if I go with anything more than 40Ah cells?
Is there any way I could opt for a logging BMS (eg Elithion 'Lithiumate Lite') alternative to the one you offer as standard with your kit?
I also have a new 200A fuse that I have not fitted yet. Can I get a credit for that and if so, how much?
Have you looked into providing either a wifi or GPRS link to the charging system to advise of problems and/or 'charge complete' SMS/email?
Regards, Martin.
Regards, Martin Winlow
Isle of Colonsay, Scotland
evalbum.com/2092
Hi Martin,
Sorry, only just saw this post.
You can convert with 40Ah, anything more and you will need a different
charger.
a 10A 153v TC Charger is ~US$500, so not the end of the world
To keep the Runke charger you will need to keep the temp sensors - if they get damaged the charger won't work.
A cycle analyst is not necessary, though useful anyway as the original fuel
guage will still work (assuming with 40Ah).
I'm happy to sell the kit without BMS or fuse, it would really then only
consist of some plastic spacers, a light bulb and a tube of noalox battery
paste. (~$200 + shipping)
I haven't used an Elithion before, if using the original charger you have
to be sure the continuous discharge from the battery is less than ~10mA,
otherwise the fuel guage will go progressively more out of sync and the
battery will eventually get over discharged.
I haven't looked at any wifi options, and won't likely in the near future
(too many projects...)
regards,
martinwinlow
Hi Matt,
Thanks for the reply.
Is the Runke problem with larger than a 40Ah pack due to the fact that the charger stops when 40Ah have gone into it rather than being controlled by the pack voltage? If so, isn't there a way to restart the charger (eg via a simple, plug-in mains timer) and fool the electronics into thinking there is less energy in the pack than there already is?
Regards, Martin.
evalbum.com/2092
Vectrixuwe
It is so easy. I changed the Runke to the ESD. With 42 Cells I charged with no Limit up to 156 Volt only with 3 Ampere 3,75 Volt Balancer. I spend for all 3000 €. So the charging goes up to 9 kwh after 200 km.
All time good ride
Uwe
If you start with the fuel guage being empty, the most the Runke (or ESD charger running nimh firmware) will put out is 32Ah (CP stage) + ~3Ah (CC and EQ stage).
once the fuel guage is full (32Ah is full scale), the charger stops.
regrettably no
if you restart the charger it just shuts down again as the fuel guage is showing full.
the only way is to reset the fuel guage.
There are two ways to do that:
1) use the usb CAN adapter and a laptop
2) hold the voltage down below 115v for a period of time
the later is possible with a contactor and resistor, in theory at least.
martinwinlow
Hi Matt,
(I suppose all this should probably be on the original lithium conversion thread)
So, using the NiMh charger firmware, the only advantage to having 40Ah of Li instead
of 30 of NiMh is that you get a full 32Ah energy (and comensurate improvement in range), 10% better acceleration due to reduced voltage sag and lower pack weight; 65kg (Li) Vs 90kg (Ni), and as the cells are not stressed due to only using 80% of their max capcity, a long service life, assuming a good BMS?
If so then, actually, that's a pretty good improvent, really!
I assume the 32Ah limit is software based?
I have my old ESD charger which has a blown thermistor if you are interested I could post it for post cost only...
evalbum.com/2092
Hi Martin,
acceleration improvement is greater than you think - lower voltage sag means the controller draws more current, so the power increase can be very substantial (on a 25 deg day with CALB 40Ah cells you would be looking at a peak of 220A @ 126v)
you much of an improvement depends somewhat upon how good or bad your nimh battery was
being able to consistently get 32Ah without experiencing disappearing bars is primary advantage of going lithium though.
the 32Ah limit is indeed software based - no way to get around it with a Runke/EVPS charger.
aside from switching to a TC Charger of course (for around US$500 if buying directly from china)
I have a bit of a pile of dead ESD chargers - I haven't really got a plan for them, they're too hard to fix.
I have a few ideas but suffer from too many projects
fixing MC's is a higher priority at the moment, due to their expense and lack of viable alternatives
