Vectrix Battery Dimensions, Pictures and Specifications
These pictures show the front (smaller) and rear battery of the Vectrix VX1:
These pictures show their weight (and one way to lift them out if you look carefully):
This photo shows all 12 modules and their connectors.
The two thin cables are not part of the battery, they just show where the short ends of the blue connector will be connected.
The other connectors are laid out close to where they would be bolted on during battery reassembly.
Here you can see the labels with individual cell numbers and module numbers, as well as the Celsidot which is on each module:
Here are some photos showing the anatomy of a Module:
- sarim
- Edd
- OlaOst
- Iber
- AndresV10
Comments
More photos
Gold Peak Batery Datasheet
The datasheet showing this 10-cell module is probably the right one for the Vectrix cells.
The Vectrix Battery Modules are made up of 9 or 8 cells, though!
http://www.evbtech.com/Data%20Sheet%5CTDS%2010GP30EVH.pdf
